calculating mass flow rate through interior holes |
March 20, 2018, 13:18 |
Tyler Richardson
Rep Power: 9 |
Hi, I have many holes that have an incompressible fluid flowing through them. I'd like to be able to create a plane by specifying a centroid and normal, and a size to that plane (either rectangular or circular) and calculate the averaged mass flow traversing that plane. (this would be repeated for all interior holes)
Is this possible in CFX? Any help would be greatly appreciated! |
March 20, 2018, 17:31 |
Rep Power: 144 |
You can define limits to planes in CFX. It is a bit weird so alternatives include drawing the entire plane, then using contours of x and y or radius to define the shape and generating a user surface on the contour line. This is more complex but you get better control over what you are doing.
March 21, 2018, 03:49 |
Gert-Jan
Rep Power: 28 |
Hi Taylor,
You mention CFX. But do you mean you want to monitor the flow through the holes during your run? Or after wards in the postprocessing? You can do the first by creating internal surfaces in each hole, mesh them and then in CFX-Pre define interfaces there. This allows you to monitor the flow through each hole. The latter case, in CFD-Post, is very simple. I do it on a daily basis. You can create a plane based on a point an a normal. Then you can limit the size of that plane given a rectangular or circular shape, so that it covers only the hole of interest. Then if you calculate the mass flow through that plane, it limits itself to the shape you provided. Or, as an example, you can calculate the mass flow average Temperature. |
average, cfx, mass flow |
Mass flow rate: calculation v/s computation | beguxa | FLUENT | 5 | December 2, 2018 22:02 |
calculating mass flow rate | mohit68 | FLUENT | 2 | March 6, 2018 12:54 |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 19:11 |
mass flow rate... | sanjar | OpenFOAM Running, Solving & CFD | 1 | December 2, 2013 01:09 |
Calculating mass flow rate | cfd novice | FLUENT | 1 | April 3, 2008 19:31 |
