Frozen Vs Transient Rotor
Old   November 12, 2003, 07:30
Default Frozen Vs Transient Rotor
New User
Hi all, My understanding is that in order to run a transient simulation of, say, an impeller in CFX5.6, I need to set 'Transient Rotor' and specify simulation type as Transient. However, if I set Frozen Rotor(steady state) and again set the simulation type as Transient, what is the implication of this as far as numerics or physics is concerned.
Thanks, New CFX5.6 user
Old   November 13, 2003, 00:53
Default Re: Frozen Vs Transient Rotor
Neale
I doubt the GUI will even let you do that because the frozen rotor model only makes sense in steady state calculations.
Neale
Old   November 13, 2003, 06:23
New User
Hi Neale, Yes, I thought so too. I imagined that when I specify frozen rotor, the transient option would not be available. But it was available and I did set Frozen rotor with Transient, no error message was sent to me. The one thing I noticed was that the residuals were not being updated after every time step.
Is it correct to assume that the grids were not moving but the transient terms in the governing equations were being solved?
New User
Old   November 13, 2003, 08:23
Reemull
I imagine that the transient option is still available to you as you could be investigating the effect of say a changing inflow and are not specifically interested in the effect across your rotating/stationary boundary.
However I cannot imagine that in your case a transient solution would make any difference to your result as you have included no tranisent effects in your boundary conditions/interfaces.
Cheers
Roy
Frozen Rotor Model CFX windsim CFX 13 January 5, 2012 14:25
FROZEN ROTOR IN UNST. SIMULATIONS Spillo CFX 6 June 1, 2008 22:05
Transient Rotor Stator Model Farid CFX 2 May 23, 2008 22:37
frozen rotor sam Main CFD Forum 1 July 17, 2006 14:08
Frozen Rotor Interface (CFX 5.5) gilberto CFX 4 November 14, 2001 22:07
