Help density dependence
Old   November 11, 2003, 16:13
Default Help density dependence
Soren
I have a problem when solving for a flow inside a large tank. The dimension is 30 m in height, and a diameter of 20 m. The fluid is seawater. Temperature at the top of the tank is 279 K and at the bottom 276 K. There is a density different between top and bottom of 3 kg. Density top is 1024 kg/m3 and at the bottom it is 1027 kg/m3. Since the tank is 30 meters in height the is also the hydrostatic pressure.
I have define a fluid with the properties of water and a new density. The density and temperature field is set as initial conditions.
How should I set this correctly. It seems like I do not get a stabel solution the temperature field and density field is moving around
Thanks a lot in advance.
Regards
Soren
Old   November 25, 2003, 21:30
Default Re: Help density dependence
zjmjm
You can open the expression editor , edit the function Density To Temperature and High(Pressure),Then select the Expr. button, the last type the name of the function Density to the temperature and the pressure
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 15:20
Variable Density Function ryzd FLUENT 1 August 25, 2011 15:16
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
Warning 097- AB Siemens 6 November 15, 2004 05:41
variable density water Atit Koonsrisuk CFX 2 July 24, 2003 04:07
