Why the streamline passes through blades
Old   November 10, 2003, 01:42
Default Why the streamline passes through blades
Jeniffer
Hello friends,
I simulated a baffled mixing tank. Two domains are set up. Central domain containing the blades is rotationary and outer domain containing baffles is stationary. There are six vertical blades revolving at the center of the tank. When I check the results in Post, I found the streamline pass through the blades. I used Thin Surface boundary (Wall) condition for the blades. Since I assigned a velocity for the whole ratotionary domain, the blades should be stationary relative to the rotationary domain. Also, stremline should pass around rather pass through the blades since blades basically are wall. Anybody can give me some suggestion about that?
I am looking forward to your any resonse.
Thanks,
Jeniffer
Old   November 10, 2003, 17:18
Default Re: Why the streamline passes through blades
Hi Jeniffer,
In CFX-Post, have a look at the properties of the streamline. Under the limits tab there are a number of options for controlling how the streamline is integrated. A possible cause for your problem is that the default integration tolerances are too coarse. Try reducing the integration tolerance.
Note that it will take longer to calculate the streamline when you do this, so don't go overboard and make it rediculously fine, especially if you are calculating streamlines on a large simulation.
Glenn
Old   November 18, 2003, 02:25
Jeniffer
Hi, Glenn Horrcks,
Thank you for your kind response. I set the integration limit to 0.00001 and the problem still is there.
Could you please give me more suggestions?
Thanks,
Jeniffer
streamline plot for multiphase problem lionlove0903 OpenFOAM Post-Processing 2 March 14, 2011 16:25
How to model intersecting blades in turbogrid Adam1181 ANSYS Meshing & Geometry 1 May 17, 2010 10:24
helicopter blades cfd-star Main CFD Forum 1 May 23, 2004 15:24
helicopter blades cfd-star FLUENT 0 May 21, 2004 07:06
Streamline diffusion Hong Main CFD Forum 0 May 18, 2000 09:10
