Rep Power: 8 ![]() |
I am trying to conduct fluid analysis on a screw compressor.
The design is something like in this video. https://www.youtube.com/watch?v=Pu5YX_qIPVo The video employed a TwinMesh meshing software and CFX solver to efficiently run the analysis. Apparently, I do not have the TwinMesh Grid software, so I am stuck with ANSYS Meshing. How would one mesh something like this in ANSYS so it will work for CFX. I understand fluent has dynamic meshing, but what about CFX? |
Rep Power: 144 ![]() ![]() ![]() ![]() |
That simulation was likely done using immersed solids, not dynamic remeshing. There is a tutorial example of a screw compressor with immersed solids on the CFX tutorials (available from the ANSYS Customer webpage).
You can do this with dynamic remeshing. CFX supports this through an interface with ICEM. Again, examples are on the ANSYS Customer webpage.
#4 | |
Regarding dynamic remeshing, my problem is a super charger where the screws are rotating and compressing the gas. Can I get by sliding mesh? or am I stuck with dynamic remeshing? |
Gert-Jan
Rep Power: 27 ![]() |
This is Twin Mesh. For sure.
With Twin Meshing tool from Berlin, you have to make a mesh for every degree of rotation and read these meshes in for each time step. So there is quite some meshing to be done for one rotation of the twin screw. And a lot of bookkeeping. :-) But at least you can get it done. Immersed solids is also a possibility but by far not as accurate as the twin mesh method. But if accuracy is not really necessary, you can get an idea of the flow using immersed solids. Not sure if you can combine it with compressible gas. But I think it will do. Forget Dynamic meshing for this application. Not suitable. Not even in Fluent. Your gap is way too small. Sliding meshing is completely out of the question, since there is no sliding interface. So, if you want this to be solved accurately, buy a license. Period. Or hire someone with a license. I don't sell it, nor have it. |
Cemal
Rep Power: 0 ![]() |
did you solve this problem? How? I have same problem now.
I did not. I lost the project, because I could not do it. If you come up with an answer, would appreciate sharing some tips
Gert-Jan
Twin Mesh is the only succesfull solution I have seen so far.
Ánd I don't have it nor sell it. |
compressible, dynamic mesh, rotating bodies |
Screw Conveyor Simulation | Zahoor | ANSYS | 0 | February 10, 2016 01:52 |
Archimedes Screw Turbine | Shaun Waters | Main CFD Forum | 1 | June 27, 2015 01:57 |
Rotational axis for hydrodynamic screw | SirLankyIII | FLOW-3D | 0 | June 2, 2014 03:29 |
fluent and screw compressors | Suresh | FLUENT | 2 | September 28, 2004 21:25 |
create screw in CFX built | methee | CFX | 1 | July 8, 2003 22:28 |
