October 22, 2003, 08:39 |
CFX-Post: Area@iso-surface
I have a quetion about how to calculate the plane area inside a iso-surface. I have a jet flow from a nozzle at different timesteps. But I would like to calculate the plane area inside the iso-surface for 20 m/s. I know where the plane is, but I am unable to get CFX-Post to calculate the area inside the iso- surface. I am trying to make a session file with cel, to extract the area. Any ideas on how to do this ??? Thanks in advance. regards Peter |
October 22, 2003, 09:44 |
Re: CFX-Post: Area@iso-surface
Peter, can you define a user surface using the intersection between an isosurface and a plane ? Or can you create a user surface from a contour that is located on the plane and has bounds defined by your iso-surface criteria ? Just a few ideas, no promisses as a collegue is using post at the moment so I can't test them for you ! Bob
October 22, 2003, 10:36 |
Hi
Thanks for the reply. But how can I create a user surface from the intersection between isosurface and plane. When I try to create a user surface the only option I have is a boundary list and location. And in the boundary list there is only the outer boundarias for the domain. Do I have to program it in cel/ccl ??? Hints is welcome. Regards Peter |
October 22, 2003, 10:58 |
Hi Peter,
Go with Bob's second suggestion. You can create a user defined surface as a contour level. First, create a contour plot on your plane with 2 contour levels and define the min to be very small and the max value equal to your isosurface value. Now, create a User Surface using the 'From Contour' method and select the appropriate contour and contour level. The User Surface created will now be entirely inside your iso-surface. Regards, Robin |
October 22, 2003, 11:06 |
Hi
I can seen that since I only have 5.5 installed and have not seen this option. I need to switch to 5.6. Right ? Regards peter |
October 22, 2003, 12:17 |
Yes. Why are you still running 5.5?
-Robin |
October 23, 2003, 02:29 |
Company has not upgraded yet. Regards Peter |
August 19, 2013, 12:39 |
Emily Imdieke
Rep Power: 13 |
I was just wondering what type of script you used to export the surface area? I am currently trying to do the same. |
August 19, 2013, 19:17 |
#9 |
Rep Power: 144 |
No need to export. Just use the function calculator and it will give you the surface area of any surface object.
viewing cfx post while working on cfx solver manager | HMR | CFX | 5 | March 9, 2011 23:33 |
Assign new variable in CFX Post | Ben | CFX | 1 | August 25, 2008 15:59 |
CFX Post processing | aditya | CFX | 1 | July 6, 2008 13:09 |
CFX 11, post | Anant | CFX | 1 | June 24, 2008 12:03 |
creating expresions in cfx build or cfx post | alex | CFX | 1 | August 22, 2002 14:01 |
