Rep Power: 8 ![]() |
I have a pipe enclosed in insulation bricks. There is air inside the pipe. There is no mass flow and radiation is turned on for air domain. one side of the pipe is hotter then the other side therefore I get positive radiation flux on cca 1/3 of the pipe and negative flux on the remaining 2/3. I am interested only in positive radiation flux and dont know how to count it with an expression or function calc. I want to do areInt of radiative flux but only for positive values. The surrounding is around 700C so radiation is important for me. Is it even possible? thank you very much |
Gert-Jan
Rep Power: 27 ![]() |
Why don't you create a new variable in Post? Something like max(0 [W/m^2],Wall Radiative Heat Flux) and integrate this new variable?
Thank you sir very much. It worked. I thought that max function was only to calculate the maximum value of given variable. Didn't know it could be used this way.
Gert-Jan
The maximum of a variable at a certain location can be found using maxVal(....)@location
Total heat transf. rate vs Total surface heat flux | Renato Sousa | FLUENT | 1 | April 14, 2020 03:27 |
Negative Total heat flux at inlet | Tleja | FLUENT | 0 | August 18, 2016 01:53 |
Monitor Total Heat Flux | TomM | FLUENT | 3 | April 12, 2016 07:40 |
total mass loss/gain--simulating taylor couette flow | nwpukaka | OpenFOAM Programming & Development | 0 | February 12, 2014 18:57 |
total mass flux correction for compressible fluid? | Francesco Di Maio | Main CFD Forum | 0 | August 21, 2000 04:23 |
