October 15, 2003, 17:30 |
Y+ values in ANSYS/FLOTRAN
I had a chance to speak to one of the FLOTRAN developers on the issue of the recommendation of y+ values in the FLOTRAN manual. The manual states that y+ values up to 5000 can be used in a favorable pressure gradient. Some doubt was expressed in this forum
The recommendation comes directly from White's Viscous Fluid Flow book, section 6-4.1. Figure 6-9 shows the validity of wall laws by plotting experimental data for several flow types (separating, adverse, favorable). For strong favorable flows, the wall law is valid up to y+ vlaues of 5000. The important point here is that you must evaluate your grid based on flow type. A general guideline that y+ should be less than 350 is not good for all situations. This message is in response to an old post in this forum |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 07:55 |
max node values exceed max element values in contour plot | jason_t | FLUENT | 0 | August 19, 2009 12:32 |
exact face values | RubenG | Main CFD Forum | 0 | June 22, 2009 12:09 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 13:04 |
Y+ values in ANSYS/FLOTRAN | Franklin Palheiros | CFX | 6 | June 26, 2003 10:06 |
