March 5, 2018, 18:06 |
Multiphase flow setup
Hi Everyone,
Which multiphase model should be setup in CFX for my project? I would like to modeling the blood and contrast agent mixing in a linear vessel. The geometry consists of a larger diameter pipe in which a smaller diameter pipe is inserted. Smaller pipe modeling the catheter which through the contrast agent is injected. I need to study particularly the mixing of the phases depending in inlet velocity. I don't have any knowledge of Free Surface Model or Surface Tension Model. The important datas: Large pipe length: 100 [mm] L.p. diameter: 3.82 [mm] Small pipe length: 10 [mm] S.p. diameter: 2 [mm] Blood -inlet velocity: 0.25 [m/s] -density: 1055 [kg/m3] -din. viscosity: 0.0034 [Pas] Contrast agent -inlet velocity: 2.59 [m/s] -density: 1399 [kg/m3] -din. viscosity: 10 [cP] Thank you in advance for any advice. Best regards, Levente |
March 7, 2018, 00:42 |
Terry
Rep Power: 8 |
I would like to learn something too
Data about multiphase simulation is rare on the internet... |
March 7, 2018, 11:54 |
Rep Power: 18 |
March 7, 2018, 17:40 |
Rep Power: 144 |
Lots of tutorials are on the ANSYS Customer webpage, and ANSYS support has even more available.
March 9, 2018, 00:56 |
Terry
Rep Power: 8 |
March 9, 2018, 01:31 |
Terry
Rep Power: 8 |
#multiphase #cfx #mixing |
multiphase flow ,mass and volume fraction imbalance | sope111 | CFX | 16 | September 3, 2018 01:10 |
Reference pressure on Multiphase flow | Roose28 | CFX | 1 | December 9, 2015 18:29 |
multiphase flow | leon_jar | CFX | 8 | November 4, 2015 03:06 |
Simulation of a Multiphase flow in a Convergent-Divergent Nozzle | RR16988 | FLUENT | 1 | June 9, 2015 07:10 |
Multiphase flow in atomiser | santhosh1987 | FLUENT | 0 | May 12, 2011 05:26 |
