2 way or 1 way coupled
Old   March 5, 2018, 09:40
Default 2 way or 1 way coupled
Dimitrios S. P.
Pled is on a distinguished road
I have a problem that needs solution. I want to simulate a microfluidic pressure driven fluid flow in a square section microchannel in STEADY STATE and watch the tube's deformation. Do I need to make a 1 or 2 way coupling between the cfx and structural?
Pled is offline   Reply With Quote
Old   March 5, 2018, 14:49
Gert-Jan
Gert-Jan will become famous soon enough
Strange question in steady state.
If the deformation is large, do it 2 way.
If small you might get away with 1 way. But if it is small, then way do you want to study it anyway?
Gert-Jan is offline   Reply With Quote
Old   March 5, 2018, 17:44
The choice between 1 way or 2 way depends on how the fluid flow is coupled to the motion. If the motion is small enough that the fluid flow is not going to change significantly then 1 way is OK. If the motion is large enough that the fluid flow will change because of the motion then you need 2 way coupling.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ghorrocks is online now   Reply With Quote
Old   March 5, 2018, 18:40
Gert-Jan
@Glenn, You mention motion. If I assume you really mean the motion of the wall, then the simulation is not steady state, but transient.
If I assume you don't mean motion but the final deformation of the solid, then it is possible to apply a steady state calcultion.
@Pled: If deformation is significant, the final shape of the solid at the end of a (in fact transient) deformation process, can be determined in a 2-way steady state calculation. Then the deformation is calculated in structural and the new shape is transferred back to CFX which will determine the effect of the deformation on the flow and vice versa several times.
In a 1-way calculation the steady state pressure distribution on the wall is calculated in CFX and is tranferred to the structural part to determine the deformation. The deformation is not transferred back to CFX. This is only valid if the deformation is small.
Bottomline, the choice for 2 or 1 way depends on if the deformation is significant or not.
Old   March 5, 2018, 18:45
Thanks for the clarification - I should have said deformation, not motion.
fsi
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
How to give Two-way coupled and one-Way coupled at a time in fluent? krishna.n FLUENT 0 June 27, 2016 08:09
Divergence detected in AMG solver: pressure coupled n.jithin.1991 FLUENT 6 January 5, 2014 12:43
Some confusion about coupled solver for incompressible flow bearcat Main CFD Forum 0 February 14, 2010 21:40
Coupled 1D/3D STAR-CD Training CD adapco Group Marketing Siemens 1 November 13, 2002 16:48
