Binama Maxime
Rep Power: 11 ![]() |
Hello !
I wanted to know about how i can know the exact value of Static Pressure at the outlet of a Pump turbine to meet a certain experimentally found Head value. I have already set the inlet Boundary conditions to mass flow in. Thank you ! |
Gert-Jan
Rep Power: 27 ![]() |
Heat at the oulet = Total Pressure = Pstatic + rho/2*v^2
Since you know the massflow, you should be able to calculate the average velocity at the outlet. From that, you can calculate Pstatic, not? The accuracy depends on the velocity uniformity at the oulet. You should determine that using CFD. It it not very uniform, then you might be a bit off. But then that is something to optimize. :-) |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
