homogeneous turbulence model for inhomogeneous multiphase flow simulations?
Old   March 4, 2018, 21:51
Default homogeneous turbulence model for inhomogeneous multiphase flow simulations?
Terry
TerryNiu is on a distinguished road
Hi friends!
Why cfx will recommend me to select homogeneous turbulence model for inhomogeneous multiphase flow simulations?
It said"It is recommended that a homogeneouos turbulence model is used for inhomogeneous multiphase simulations with more than one continuous phase"
TerryNiu is offline   Reply With Quote
Old   March 5, 2018, 05:33
Where does it say that?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 6, 2018, 01:32
Terry
In CFX help-Modeling Guide-Multiphase Flow Modeling-Modeling Advice for Multiphase Flow
It said: For flows in which the phases tend to separate (for example, inhomogeneous free surface flows and oil-water separators), the homogeneous turbulence model is recommended.
Obviously, oil and water are not two mutually soluble liquids, why homogeneous turbulence model is recommened?
Thanks
Old   March 6, 2018, 05:24
Gert-Jan
Gert-Jan will become famous soon enough
Homogeneous means that CFX will apply the same turbulence model in each phase. So laminar, k-e, SST, RSM, whatsoever: in both phases the same turbulence model. For a case where oil and water are separated (inhomogeneous), it is safe to use this.
You can overrule this if you want. If you have good reasons to do so,
Gert-Jan is offline   Reply With Quote
Old   March 7, 2018, 00:22
Terry
Oh I see now. That means each phase will obey the same turbulence model, isn't it?
Thanks for your detailed explaination!
Old   March 7, 2018, 00:52
It means more than sharing the same turbulence model. It means all phases will share the same turbulence field as well. So if one phase has k=10 at some location then all phases have k=10 at that location.
Old   March 7, 2018, 02:00
Terry
Thank you very much!
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Inhomogeneous and homogeneous multiphase flow Saturn CFX 2 June 30, 2006 04:51
Turbulence model in flow driven by surface tension Z. ZENG Main CFD Forum 7 April 28, 1999 08:18
