heat transfer from solid with fixed wall temp to fluid |
March 3, 2018, 16:43 |
Rep Power: 9 |
I want to set in CFX fixed temperature to one wall and want to simulate heat transfer from this wall to another fluid domain. When I set fixed temp there is no heat transfer to the air. Is it ok to set also boundary for the same wall in air domain as fixed temperature? Or is there any other way? Thank you very much |
March 4, 2018, 06:36 |
Rep Power: 144 |
Yes, you can do this. If you are getting no heat transfer something is wrong with your setup. Is this a single domain or multi domain simulation?
March 4, 2018, 07:20 |
Rep Power: 9 |
Thank you for your answer. There is no heat transfer because as soon as you set fixed temp for that face the interface between fluid and solid disappears and therefore there is no conservative interface flux. I just wanted to know of the physics is the same when I set the fixed temp for the same face in both domains. I also found a solution where I set energy source with CEL expression so I get the desired temp in solid body
March 4, 2018, 10:48 |
#4 | |
Rep Power: 18 |
March 4, 2018, 17:53 |
Rep Power: 144 |
You cannot define fixed temperature on an interface. Because then it is not an interface, as you have defined the temperature instead. So in this case you need to define a wall on both the fluid and solid domain and remove the interface. Make them both fixed temperature walls - the default is adiabatic walls and I suspect this is what you are seeing.
March 4, 2018, 18:57 |
#6 | |
Rep Power: 9 |
Anyway thank you for your help |
March 4, 2018, 19:00 |
Rep Power: 9 |
Nope everything was ok. I just thought that it works somehow different. You cant set fixed temp boundary for one face and have automatic heat transfer from solid to fluid because there is no interface after you had created boundary.
March 5, 2018, 03:26 |
urosgrivc
Rep Power: 12 |
I think that your problem is ""and whhen you dont have interface you cant have heat transfer""
You dont even need a solid in this case if you know that the wall temperature is at some fixed temperature,just use the fluid domain with that wall set to fixed temperature there is no inteface involved in your simulation |
March 5, 2018, 05:17 |
#9 |
Rep Power: 144 |
That is correct. If the interface between the solid and fluid domain has a known temperature, then there is no need for a multiple domain simulation as you can run separate solid and fluid simulations. That is much easier and quicker than a combined simulation anyway.
March 5, 2018, 17:53 |
#10 | |
Rep Power: 9 |
Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 03:55 |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Solid / Fluid Heat Transfer | Koranten | FLUENT | 3 | March 19, 2011 08:21 |
