Error finding variable RCOEF_SL1 (monte carlo radiation for solid)
Old   March 2, 2018, 07:38
Default Error finding variable RCOEF_SL1 (monte carlo radiation for solid)
sortik is on a distinguished road
Hello all,
I am getting this error during first iteration. Let briefly explain my simulation setup. I have steel enclosure with insulated walls. Enclosure consists of 2 chambers separated by glass plate. Bottom chamber has heat source inside. Since I have to also count with a radiation trought glass plate I have to turn on monte carlo model for this solid. As soon as I turn this on I get the error
Error in subroutine FNDVAR :
7 Error finding variable RCOEF_SL1
7 GETVAR originally called by subroutine get_SEMISS_CSBELG
I did first simulations with discrete transfer model for air domains and everything was ok so the error is connected with turning the monte carlo on for solid domain. I set up interface between glass plate and air domains so there si radiation conservative flux and set monte carlo for air and solid domain.
I am enclosing my ccl settings and will be very grateful if you can help me. Thank you very much
sortik is offline   Reply With Quote
Old   March 2, 2018, 08:08
I also tried transfer mode "surface to surface" and turning on total energy for air domains. Error still persists
Old   March 7, 2018, 16:01
I figured it out. The problem was that I turned on radiation for one solid domain (transparent glass) and left it in default solid solid interface with other solid domains that didn have radiation turned on. This also happens for the fluids.
rcoef_sl1
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
Cavity air flow with radiation – result variable Yingchun CFX 1 November 25, 2005 12:13
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
