February 27, 2018, 13:55 |
Applying boundary conditions, porous media
Swapnil Rane
Rep Power: 9 |
I'm modelling a cork with the following BC's.
two outlet's pressure-- 1 atm pressure inside the cork-- 1.4 atm How do I set up the pressure's in CFX? Which pressure BC should I select in domain setting tab? |
February 27, 2018, 14:49 |
Rep Power: 144 |
Please show an image of what you are modelling and the boundary conditions you propose to use.
February 28, 2018, 18:44 |
More data
Swapnil Rane
Rep Power: 9 |
the boundary conditions are as follows---
Two outlet's are at atmosphere, which pressure's to select? static or total? Cork is compressed-- 1.481 [atm] pressure. oxygen flows through it. porosity-- 0.2 permeability-- 2E-10 [m^2] How do I setup the pressure's for this problem? Also, should I add oxygen source point inside the cork? |
porous. cfx, pressure based solver |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Problem on boundary conditions (multi-phase, porous media, 3 flow domains) | Juun | FLUENT | 1 | November 19, 2023 01:06 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
