Two phase simulation - velocity of water above air-water interface isn't zero |
February 27, 2018, 11:12 |
Rep Power: 15 |
I have a multiphase simulation of mixing vessel (water has been mixed and air is above water while vessel is closed on the top). When I check the results and velocity contours of water (water.Velocity) on some vertical plane, I get non-zero velocity of water above the water level. What is the reason for that? Besides, volume fraction of water is as expected (0 above water level and 1 below water level). Thank you. |
February 27, 2018, 15:58 |
Rep Power: 144 |
I assume you are doing a homogenous free surface simulation. In these simulations there is a single velocity field which is shared for both water and air. So the post processor will show water.Velocity everywhere, even locations where the water volume fraction is zero. This holds for inhomogenous free surface simulations as well, the velocity field of all phases covers the entire domain, even where the volume fraction is zero.
February 27, 2018, 16:30 |
Rep Power: 15 |
Hi ghorrocks,
Thanks for your reply. Does it mean that I can't see air velocity field although in case of inhomogenous simulation? Shouldn't each fluid have it's own velocity field in that case? |
February 27, 2018, 16:37 |
Rep Power: 144 |
Regardless of whether the simulation is inhomogeneous or homogeneous, the post processor will show velocity fields for all phases, eg air.Velocity, water.Velocity. In a homogeneous simulation the air.Velocity and water.Velocity fields will be the same.
February 27, 2018, 16:45 |
Rep Power: 15 |
Ok, so I am able to observe the difference in velocity fields for air and water in case of inhomogenous.
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
2 Phase Flow, Gas Jet into Water Simulation Method | im_lenny | OpenFOAM | 3 | May 4, 2017 04:20 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
