CAD tools for ship CFD
Old   October 2, 2003, 06:18
Default CAD tools for ship CFD
Boris
We are trying to use CFD simulations as an approach to modify hull forms in order to achieve better ship hydrodynamic performances.
However, at the moment, we don't have good CAD tools. Each time, we use ship offsets to create the model geometry and do the modeling. After the simulations, we may find out some parts of the hull from that can be modified. Then, we can't change the hull form in a easy way, as we don't have an appropriate CAD tool to change the hull form and to do the faring as well.
Please kindly provide the info of what CAD tools nomarlly used for ship CFD.
Thanks in advance.
Old   October 2, 2003, 12:45
Default Re: CAD tools for ship CFD
Robin
I cannot offer much specifically on ship modelling, but it sounds like what you need is the ability to define you model parametrically. Most commercial 3D CAD applications allow you to do this.
If you are only creating a CAD model for simulation and do not need a full featured CAD system, the CAD tool in CFX-CAD2Mesh, ANSYS DesignModeler, is a very good Parasolids based CAD system and will allow you to define your model parametrically. This model would then be directly linked to the meshing application, allowing you to easily update your mesh with your model changes.
Regards, Robin
Old   October 2, 2003, 21:00
Boris
Thank you very much, Robin,
I need a CAD tool specially designed for ships and it can be easily linked to CFD preprocessor as well. After I change any geometry parameters, the hull form surfac needs to be fared to become smooth again. Nomal CAD pakages don't have faring tools for ship forms.
Thank you again.
Old   October 3, 2003, 14:54
James Date
Hi there, You might what to buy the following package for ship lines fairing and exporting.
Wolfson - Ship Shape - Cost £1000
http://www.wumtia.soton.ac.uk/software.html
This program is very easy to use and should do what you want without being overly complicated.
You could try Maxsurf, although this package probably costs a lot more than ship shape
Regards James
Old   October 6, 2003, 04:56
Louwrens
Hi Robin
With regards to CAD2Mesh, will the Parametric CAD system be available to "all" users, or do you have to buy a special license for that (like the parasolids modelling in Build / Patran?)
Just asking... ;-)
Louwrens
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 13:26
Treatment of ill-conditioned system of equations by CFD tools shreyash08 Main CFD Forum 0 August 4, 2010 11:13
CAD-embedded CFD or CFD-embedded CAD ? D Main CFD Forum 1 January 29, 2006 15:59
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
