Problem in importing new material added in engineering data library to CFX-Pre
Old   February 27, 2018, 03:57
Question Problem in importing new material added in engineering data library to CFX-Pre
Ghada
Ghada is on a distinguished road
Hello everyone!
I have added a new material into the engineering data in ansys workbench but it doesn't appear in the CFX-pre when I manage the set ups and I don't know how to import it to my simulation!
Thanks.
Ghada is offline   Reply With Quote
Old   February 27, 2018, 09:37
urosgrivc
urosgrivc is on a distinguished road
I dont think that is posible:
You must make a material vithin cfx-pre
or import it as CCL file
I dont know were did you even find engineering data in cfx tree ?
because there is none
urosgrivc is offline   Reply With Quote
Old   February 27, 2018, 13:59
Ghada
Actually it was not in the CFX tree, I used the one from the toolbox in the workbench.
Anyway, when I save the new material as an engineering source, it can only be saved (.xml). Can you tell me how can I save as CCL file?
Old   February 27, 2018, 14:04
urosgrivc
leave the engineering data alone it has nothing to do vith cfx
create the material inside cfx pre
Old   February 27, 2018, 14:13
Ghada
Actually I want to add a nanofluid with properties that vary with temperature..and adding a material inside the cfx-pre doesn't allow me to do so unless I have some certain formulas.. Am I wrong?
Old   February 27, 2018, 14:21
urosgrivc
Yes temperature dependant properties are posible in cfx by inserting an expresion vhich is temperature dependant, a lot more is posible also.
You can make it like this:
create user function, create a table of properties
make an expresion vhich calls your userfunction(T)
insert this expresion as a material property
engineering data, engineering data source, new material definition
Importing profile data in CFX cardioCFD CFX 9 September 30, 2023 05:14
problem in importing force-time data from excel into ansys dky Structural Mechanics 3 November 22, 2017 11:25
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
error message cuteapathy CFX 14 March 20, 2012 07:45
