CFX build 5.6
Old   September 9, 2003, 15:42
Default CFX build 5.6
Richard
Hello All Experts
I seem to have a problem trying to use the mouse functions such as zoom, translate, drag etc, when using CFX build on the LINUX O/S.
I have looked through the manual and can't find any help regarding configuration in cfxbuild 5.6. Does anyone out there know what I need to do to get all the mouse features to work as normal. Everything works fine when I use CFX_post???
Can anyone help me....???
Cheers
Old   September 9, 2003, 17:17
Default Re: CFX build 5.6
jonathan
Richard,
I have the same problem. I don't think rotate is supported in Build for LINUX. To translate or zoom, use the middle mouse button with the Shift or Ctrl key respectively. Does that help?
Not having the rotate feature is somewhat inconvienient, but can be over come with a bit of persistance.
Jonathan
Old   September 9, 2003, 17:21
Richard
Hello Johnathan
Thanks for getting back to me so quickly!
I will try your suggestion. Thanks
Richard
Old   September 9, 2003, 19:52
Robin
This does work with Linux. Make sure your middle mouse button function is not being overridden by your window manager.
Robin
Old   September 10, 2003, 02:54
matej forman
Everythink works fine under Linux. Make sure, your NumLock key is off!!!
ps:it does not work for me under Windows (2000). Also the rendering of the black screen is not working properly. Is there any interaction with the Xserver? Has anyone any idea where could be the problem?
matej
Old   September 10, 2003, 04:32
Richard
Hi Matej
I have it set up on windows 2000 and everything works fine.
I have managed to get it working on Linux also (mandrake 9.0) and all appears to be ok now. What version of X are you using on Linux, I am not sure if this makes a difference but I am using version 4.x.x,?
Old   September 10, 2003, 05:24
matej forman
I have mandrake 9.1 and its default X version: 4.3 patch level 5mdk to be precise.
I guess, while it is XFree86 4.x.x.. the 'x's do not matter that much.
I'm giving up on Windows.
matej
Old   September 10, 2003, 11:23
jonathan
Turning Num Lock off solved my problems. Thanks. That had been bugging me for a long time.
Jonathan
Old   September 10, 2003, 13:20
Astrid
Search for the file /etc/X11/XF86Config
Make a copy first! Then search for
Section "InputDevice"
Identifier "Mouse0"
Make the section look like below:
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Device" "/dev/psaux"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "no"
EndSection
Especially the "IMPS/2" did the trick for me. If it does not help, you can set the last option to "yes"
which will emulate the middle mouse button by pressing the left and right button. This is espcially
convenient if you do not have a middle mouse button at all.
Astrid
Can CFX 5.6 model combustion of a sprayed liquid? Doug CFX 0 July 3, 2004 04:46
Porous Media in CFX 5.6 Cui CFX 0 June 30, 2004 16:18
CFX 5.6: Dispersion Coefficient/ Concentration shir CFX 0 November 26, 2003 10:02
have CFX 5.6 came into market or not?? prasanth CFX 4 May 21, 2003 22:45
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
