Help me Robin!
Old   August 21, 2003, 09:26
Default Help me Robin!
Carola
One more time Robin!, I got a couple of questions to you: 1)What do you mean when you say:"... An error correction is solved on each of the coarser grids and passed back up to the finer grids to improve the solution..", I understood like with every iteration the error is reduced until it reach the tolerance value..., I´m wrong?.Where this error correction come from?.
2)What is the diference between time step and iteration?.
Sorry if I made a lot of stupid questions but I finally found someone who can explain to me this kind of things in a very simple way !
Take Care,
Carola
Old   August 25, 2003, 17:55
Default Re: Help me Robin!
Robin
Hi Carola,
The error correction is just a detail of the additive corrective multigrid method and occurs within a single iteration/timestep.
Iteration and timestep are often used interchangably. CFX-5 and CFX-TASCflow include transient terms in the equations and each "iteration" of the solver in a steady state run is also a "timestep". If you run a transient simulation, a single timestep may include multiple iterations, usually referred to a inner coefficient loops.
Hope this helps.
Regards, Robin
Old   August 27, 2003, 14:33
Default Thanks Robin!
Carola
Robin boundary condition for the velocity fumiya OpenFOAM 4 June 17, 2011 03:58
directionMixed robin Martin80 OpenFOAM Programming & Development 0 June 10, 2011 05:02
Robin B.C=Mixed B.C ? ksookhak OpenFOAM Running, Solving & CFD 5 January 12, 2011 11:33
what's wrong with my Robin boundary conditions? hadesmajesty Main CFD Forum 0 September 23, 2009 05:57
to LANGTRY ROBIN :help, hypersonic transition SST ben akih CFX 0 September 21, 2006 05:59
