August 15, 2003, 13:56 |
Multiphase non-Newtonian Flow
Hi there,
(CFX 5.6 User ) I am simulating a mixture of one continuous phase (water) and two dispersed solid phasees. Definitely the viscosity of the mixture is dependent on the concentration of two dispersed solid phases. It also is a function of shear rate. For simplicity, I want to try power law model first. But I can not understand how the viscosity of mixture is calculated in CFX particle model. In Fluid Detail, I have to assign the viscosity of both continuous phase and dispersed phase. If I tend to set the power law model for mixture, should I set it for continuous phase or dispersed phases because nowhere can the viscosity of the mixture be assigned in CFX 5.6. Thank you in advance! Jingo |
September 7, 2003, 06:41 |
Re: Multiphase non-Newtonian Flow
dear Jingo for the cfd simulation reguarding the non newtonian fluids with the solid phase as a dispersed or the contineous phase , you can use the fluent software for cfd simulation since whatever the problem u r facing u can get it from fluent.
September 8, 2003, 10:47 |
Hi Jingo,
The effective viscosity of the mixture will already vary due to the presence of the additional dispersed phases as a result of their momentum transport. Do you expect the viscosity of the individual phases to actually change? -Robin |
Multiphase flow! | Amer | FLUENT | 2 | May 16, 2012 16:57 |
consult for the multiphase flow | poiuliu | FLUENT | 0 | October 5, 2007 02:07 |
Multiphase flow information | amir | FLUENT | 2 | May 25, 2007 07:01 |
Realizable k-epsilon eqns for multiphase flow | Rana | FLUENT | 0 | December 8, 2006 14:46 |
Inhomogeneous and homogeneous multiphase flow | Saturn | CFX | 2 | June 30, 2006 04:51 |
