Calculation time : SAS model vs kEpsilon model |
February 1, 2018, 17:47 |
Rep Power: 12 |
All other things of the simulation being equal, if I use the k-epsilon model instead of the SAS model, does the simulation run faster?
Thanks |
February 2, 2018, 01:03 |
Rep Power: 144 |
Your initial assumption that all other things are equal is not valid. A k-e model will be run using RANS, so will have a mesh and time step to capture the mean flow field only. Also k-e models can be run steady state. The SAS model needs to have a mesh and time step to capture the large scale turbulent fluctuations - which will require a finer mesh and finer time step. The SAS model is transient by definition and cannot be properly run steady state.
So a properly validated k-e model should be much faster than a properly validated SAS model, but mainly because the mesh and time steps are finer and it is steady state versus transient.
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 10:54 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
