February 1, 2018, 11:43 |
Long Term analysis
Dimitrios S. P.
Rep Power: 8 |
How can I make a sim that considers time in long term?
I need to define boundaries related to time as well. |
February 1, 2018, 17:57 |
Rep Power: 144 |
Just do a transient analysis with a long total time. Make sure you have a good computer, robust backups and a reliable network/computer before attempting it.
Time is a variable which is available in CEL expressions, so you can make boundary conditions functions of time. Have a look at the CFX tutorials on how to use CEL expressions and the CFX documentation (Reference manual) on available CEL variables and functions.
February 2, 2018, 05:15 |
Dimitrios S. P.
Rep Power: 8 |
I have considered that, but I need to consider a time step of miliseconds into boundaries
for a heart sim, and evaluate the results in a period of year. I was thinking of something that could consider a periodicity in values of the first iterations and continue faster. |
February 2, 2018, 18:47 |
Rep Power: 144 |
Sounds like you have a model with a wide separation of time scales. Usually this means that you can use CFD to solve the short fluid time scales, but some other approach (possibly a simple ODE solver) to do the long time scales.
If you explained what you are trying to do we might be able to help you.
February 3, 2018, 15:25 |
Gert-Jan
Rep Power: 28 |
What questions are your trying to answer when performing the CFD-calculation of single cycle and the CFD-calculation of 1 year?
February 5, 2018, 04:41 |
Dimitrios S. P.
Rep Power: 8 |
What I am asked to do is to evaluate the plaque creation inside an artery of a heart.
To do that, plaque is expressed through the deformation of the artery wall mesh. And the plaque creation, which is the mesh deformation, is a function of wall shear stresses. I wanted to evalute the plaque progression in one, two and three years, considering the artery inlet as a sine function,but I understand this is not possible. So I am going to consider input as a fixed value, based on bibliography. Even so how can I make a model that converges for a wide variety of artery geometries? |
February 5, 2018, 05:44 |
Rep Power: 144 |
This is a classic case where you need to separate out the time scales.
On the time scale of a heart beat the plaque does not change. So simulate the heart beat assuming fixed plaque, but do a series of different plaque levels to simulate the plaque accumulating over time.
February 6, 2018, 07:47 |
Dimitrios S. P.
Rep Power: 8 |
I'll try that out with different numbers of plaque levels to evaluate the results
long term analysis, time |
Problem of SOURCE term gradient in UDS | wind | Fluent UDF and Scheme Programming | 6 | December 1, 2022 15:21 |
Flutter analysis of compressor blade | sridharabc228 | CFX | 1 | April 13, 2017 20:10 |
FSI-system coupling: "...same analysis type"? | rjw | CFX | 0 | March 26, 2017 08:25 |
How does fluent discretize the viscous term? | motorbean | FLUENT | 3 | August 25, 2015 17:38 |
Normal Stress Term in properties of Standard K-Epsilon model | MissCFD | STAR-CCM+ | 0 | April 8, 2015 16:37 |
