January 31, 2018, 21:41 |
Convergence issue with a sawtooth pattern
Eric Lee
Rep Power: 9 |
I'm trying to simulate a wind-tunnel experiment where a 4 coaches train is put. The boundary conditions are all no-slip walls except for the inlet, outlet, and the symmetry one inside. The problem I have is that the convergence monitor shows that the solver seems to have a sawtooth pattern around from 30th iteration. my question is, is it allowable to use the data acquired from this kind of result or not. on the internet it says this problem could happen if the mesh is too coarse, but the number of elements is around 22 million in my case. I would appreciate if you share your knowledge on this. Thank You. |
February 1, 2018, 01:14 |
Rep Power: 144 |
This is a FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
multiphase flow - convergence issue | sina_mech | FLUENT | 1 | September 21, 2017 02:26 |
convergence issue for transonic turbulent case | aeroiitkgp | SU2 | 5 | May 12, 2015 16:44 |
Convergence issue for high speed combustion with radiation. | Goutham cet | FLUENT | 2 | July 30, 2014 07:22 |
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX | shiyun | ANSYS Meshing & Geometry | 4 | May 9, 2012 19:55 |
CFX-Solver, issue with convergence behavior | Andy | CFX | 7 | September 5, 2006 03:24 |
