Mesh; wall function for element based finite volume method |
January 25, 2018, 13:24 |
Oskar
Rep Power: 10 |
Hello dear ANSYS CFX users.
I'm doing simulation of turbine in CFX Turbomachinery solver. Previously I was using openFoam which is a finite volume method. I know how to prepare wall function for FVM but CFX is element based finite volume method and I am not sure if I should use wall function in the same way? ANSYS Mesher sets tetrahedrons volume as default for CFX. I wonder if I should use typical hexahedrons on wall function or just refine tetrahedron mesh enough? I would like to use k-omega SST turbulence model. I wish You best. Oskar |
January 25, 2018, 17:08 |
Rep Power: 144 |
Yes, the y+ parameter is the same for CFX as for other solvers.
Refined tets in the boundary layer is not recommended in most cases. Inflation layers giving you either triangular prisms or hexs is recommended. |
January 25, 2018, 17:36 |
Oskar
Rep Power: 10 |
Thank You for Your answer, Sir. I will use triangular prisms.
Have a nice day! Oskar |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
