high velocity problem
Old   July 23, 2003, 08:21
Default high velocity problem
Kirill
Hello everyone! I am trying to calculate turbo-machine with long blades. In that case fluid velocity on the tip of blades will enormous and so calculation error will enormous too. Is there real possibility to workaround this problem in CFX?
Thank you in advance.
Old   July 23, 2003, 12:21
Default Re: high velocity problem
Bart Prast
CFX 5 can do simulations with Mach numbers till 2 perfectly. Above Mach=2 it can still do it but is less reliable. I don't think you want to have a turbine with relative gasspeeds in the high Mach number range (flow has shocks, shocks cause losses and damage)
Velocity magnitude problem Damien_CFD FLUENT 0 August 1, 2011 07:32
Reference Velocity Calculation & Convergence Problem hasan_hzl Main CFD Forum 0 January 29, 2011 14:42
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 06:36
Unbelievably high velocity magnitudes in film cooling - HELP! shankara.2 FLUENT 0 June 1, 2009 23:43
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
