January 14, 2018, 02:11 |
Volume flow rate
Engineer B
Rep Power: 11 |
Hi everyone,
I have a problem for estimating volume flow rate for flow passing over the weir and under gate using Ansys CFX software. In other software's we can find it as flux surface but in Ansys CFX i don't know how to make flux surface. so i tried 1) to estimate volume flow rate as mass flow rate by making planes in cfx post processor. but also i have a problem for making a plane only over the weir. when i make plane it covers all the domain height. these are some pictures for my simulation. Please Help 2) Other way, I tried to make thin surfaces instead of baffles in Ansys design modeler and i defined the baffles as walls in boundary conditions. but the run doesn't work and gives errors. Last edited by bshkoj; January 19, 2018 at 05:11. |
ansys 14, cfx, cfx post, mass flow rate, multiphase |
Rainfall modeling using source volume flow rate | max0014 | FLOW-3D | 1 | November 24, 2016 03:49 |
two fluid, volumetric/mass flow rate at different volume fractions | Veronique Pe | CFX | 2 | November 26, 2014 05:30 |
Finding volume flow rate through a car | wh88 | FLUENT | 0 | September 23, 2011 14:12 |
Volume of Flow Rate (VFR) boundary condition | therockyy | FLOW-3D | 0 | May 23, 2011 14:19 |
volume flow rate error in udf | jjchristophe | Fluent UDF and Scheme Programming | 1 | July 13, 2010 04:23 |
