surface and points no. -1
Old   July 10, 2003, 17:14
Default surface and points no. -1
Pascael Fonteijn
Hi all,
I have a complicated geometry consisting of different parts. I have put the parts in different groups to isolate them and to manipulate them easily. However, when I visualise the default group, I seem to have created several points, curves, and surfaces all numbered '-1'. I can't delete them and when I close Build 5.6 I get weird warnings.
How do they get there and how can I get rid if them?
Pascale
Old   July 15, 2003, 10:50
Default Re: surface and points no. -1
Min
There are two kinds "default group"
1) import geometry into DG 2) creat geometry giving name that is DG
In case 2:
Post all group select all thing modify DG add everything into DG
DG is just name and relation of subgroup up to you!
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
