Mirror velocity vector
Old   July 6, 2003, 14:56
Default Mirror velocity vector
Jackie
Hello all,
I simulated a flow just one half of the entire domain but I like to see a result in a full view. Is it posible to mirror velocity vector to the other side?.If so, Tell me how to do that please.
Jackie
Old   July 10, 2003, 05:56
Default Re: Mirror velocity vector
Reemull
Not sure what program you are using - but here's how you mirror the plot using TASCflow and it might be similar in CFX5.X
Create your plot as normal Tascflow has a bar on the RHS that allows you to set up the plot - selecting the region etc - on the top RHS of this bar there are a number of buttons (New, Delete, Copy, Rename, Attributes) Click the Attributes button - this will produce another menu that allows you to modify the plot further. In the "Set/Unset Object Attributes" section toggle on the "Mirror Plane" option. This causes a "Mirror Plane" button below to activate (it was previously grey and unclickable).
Click on the "Mirror Plane" button and set up the plane across which your plot is to be mirrored and that should be it.
If you require the mirror for more than one plot - then you need to perform the above for each individual plot you wish to show.
Hope this helps
Roy
Old   July 10, 2003, 11:56
Jackie
Thank a lot Roy.
I'm using CFX5.5.1 and I already founded it. Your suggest is very useful.
How to get normal vector to the face? Viatcheslav Kulikov FLUENT 1 August 31, 2017 04:03
Assign one vector to another - still a field? David* OpenFOAM 3 May 27, 2011 11:47
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 18:24
