Ex#3 - Integrated Quantity Boundary Conditions
Old   July 2, 2003, 13:07
Default Ex#3 - Integrated Quantity Boundary Conditions
Vinicius
Hi everybody!
IŽm a CFX beginner and I have a model quite similar to the example 3 shown in user function examples at printable books. But it doesnŽt clarify my questions on how to get fluid properties like temperature and density from a position (outlet Boundary Condition) and insert it into another position. I mean, I got a room wich is been cooled (transient) so I need to get an average temperature at the outlet surface and give it as a temperature at the inlet boundary condition. So the fluid goes out from domain, after that is cooled and return to domain. Does anyone know how to build that subroutine shown in that example? How can I do it without using User Function? What is the best choice to me?
Thanks!
Old   July 2, 2003, 13:47
Default Re: Ex#3 - Integrated Quantity Boundary Conditions
Robin
Hi Vinicius,
You can make your inlet a function of your outlet by adding the appropriate integral CEL function. For instance, if you want the inlet temperature to be 10 percent lower than the mass averaged temperature at an outlet boundary named "Exit", simply use the following expression for the inlet temperature:
massFlowAve(T)@Exit * 0.10
Regards, Robin
Old   July 2, 2003, 16:44
Vinicius
Thanks a lot Robin!!
IŽll try it!
Best regards Vinicius
Old   July 3, 2003, 13:38
Lucio
Hi Robin, This function is very interesting! Where can I get more informations about this kind of functions? Did we have this in the CFX Printable books? Regards, Lucio
Old   July 4, 2003, 01:09
Neale
Yes, look in the documentation for the CFX Expression Language. It covers all the integrated quantity functions available in the flow solver and CFX-Post.
Neale
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Boundary conditions for 2D Navie-Stockes simulation L1011 OpenFOAM 5 December 13, 2012 09:17
Proper Pressure Boundary Conditions for Buoyant Flow mchurchf OpenFOAM 0 March 25, 2010 13:16
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 07:25
