Mesh Import from Fluent to CFX
Old   June 30, 2003, 11:11
Default Mesh Import from Fluent to CFX
sam
Hello users, i will be greatful to ur contribution if u will tell me the procedure of importing the mesh from fluent ot CFX along with all the boundary conditions,thanks in advance.
Old   June 30, 2003, 15:01
Default Re: Mesh Import from Fluent to CFX
Robin
Hi Sam,
You should be able to export the mesh to a format which CFX-5 can import. If you have ICEM-CFD, you can import the mesh into MED and export a CFX-5 mesh.
This will only provide you with the mesh and 2D/3D regions. Since boundary condition specification is code dependant, you will have to re-apply your boundary conditions in CFX-5.
Regards, Robin
Old   July 2, 2003, 02:22
Neale
Sam,
You have a few options...
1) In the fluent post processor export a patran neutral file. You can then read this into CFX-Build and apply boundary conditions. This is not a workable solution if you have a large grid (i.e. >1,000,000 cells).
2) If you are smart, motivated, and have the Fluent documentation of their file format, then you can write a user defined import executable in CFX-5. The doc for this on the CFX side is in the CFX-5 manuals.
Neale
Old   July 2, 2003, 11:26
Erich
Are you unhappy with the Fluent results or just curious as to what the results would be in CFX?
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 04:42
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Import CFX def into Fluent eric_wang FLUENT 0 April 18, 2011 14:14
Import Mesh from CFX TurboGrid Txema FLUENT 0 February 9, 2007 04:45
import mesh to CFX 4 georgian CFX 1 March 19, 2003 17:35
