CFD problem setup for flow through porous media
Old   June 26, 2003, 16:52
Default CFD problem setup for flow through porous media
Paresh Jain
hi all, i m a new user of CFD and CFX i have the same problem which VIJAY has (posted 20 jun) the problem is setting of problem of flow through porous bed. so pls,if u can help in this regard i would b glad to hear from u.
Old   June 26, 2003, 17:50
Default Re: CFD problem setup for flow through porous medi
Jan Rusås
Cfx4 or 5 - the setup is very different. Actually there is a very good technical paper on the CFX community which desrcibes how to do it in CFX5
Old   June 28, 2003, 00:55
Paresh Jain
thanks jan can u pls give me the name of paper i m using 5.5.1 and 5.6
Old   June 28, 2003, 16:08
Jan Rusås
I assume that you have acces to the community. The "paper" is a technical tips. The title is modelling flow through porous media in CFX-5 ....... The link is http://www.software.aeat.com/cfxcomm...a_in_CFX-5.htm
You could also try to search the CFX-forum and this forum I am sure the problem has been raised before. Regards Jan
Old   June 30, 2003, 04:15
Vijay
Thanks for the information - Jan
Regards, Vijay
Old   June 30, 2003, 04:50
Paresh Jain
hi thanks jan for ur help............. i will go thru that paper .
Problem with rhoPorousMRFSimpleFoam and how to define porous media Amit Mathur OpenFOAM 6 July 18, 2013 07:57
Porous Media Simulation with CFX/Fluent Ghasem ANSYS 1 May 14, 2013 10:07
Modelling sound propagation through layered porous media nkinar Main CFD Forum 0 July 4, 2010 15:45
Porous media solving problem mulfal OpenFOAM Running, Solving & CFD 2 June 23, 2010 06:31
combustion in porous media burner zuby ANSYS 0 July 27, 2009 03:26
