Multi-phase Modelling
Old   June 26, 2003, 09:28
Default Multi-phase Modelling
Aaron Latty
Hello all:
I am using CFX 5.6. My experience with CFX is low. My experience with CFD is low.
I wish to set up a model that simulates two-phase flow in a vertical pipe. Essentially, I am modelling taylor bubbles. Of special concern is the entrainment area at the bottom of the bubble, however I would be glad to get the general shape modelled to get started.
I would like to get some advice on how to get a model set up and initiated properly to get bubble formation.
I would also like to know generally what kind of mesh would be best and what kind of solution times I can expect.
As I see it, I have two general options for the model. Homgeneous and Inhomogeneous. Initially, I am using the homogeneous model with free surfaces. I would like to get some reasonable results with this before attempting a nonhomogeneous model.
Any advice would be appreciated.
Thanks,
Aaron Latty
Old   July 2, 2003, 08:08
Default Re: Multi-phase Modelling
Aaron Latty
Hello?
Any takers? All I am really looking for are some general guidelines for modelling gas bubbles.
My setup is as follows:
Vertical Pipe, 50 mm diameter, 5 m length. Stagnant water to start.
Cheers!
Aaron
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
using interface with Euler multi phase model karimi Main CFD Forum 0 May 22, 2011 03:39
re:about modelling of multi phase flow satya FLUENT 1 November 20, 2009 10:41
multi phase modelling in fluent naren FLUENT 1 January 25, 2005 13:31
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
