Problem on boundry of two phase flow
Old   June 24, 2003, 23:08
Default Problem on boundry of two phase flow
youngan
hi,all I have trouble to define an outlet of gas-solid two phase flow, which gas phase can pass through while solid phase can't. How can i achieve this.
Old   June 25, 2003, 07:43
Default Re: Problem on boundry of two phase flow
Jan Rusås
I assume that you are talking about an euler-euler solution. I had a similar problem once (in CFX4.4), I think I solved the problem by setting ambient conditions for the solid phase to zero and solved the problem as transient. (I had to solve it transient because I only had one outlet and the solver will try in a steady state to equalize inlet-outlet.) Hope it helps
Old   June 30, 2003, 03:11
youngan
Thank you for your suggestion. you are right, i am talking about an euler-euler solution and my problem is similar with the one you once meet. But my problem still remains. My problem is as follow: Gas-solid flow goes into a tank through an inlet and there is an outlet which only gas can pass through. so the solid remains in the tank. But i do not know how to difine such an outlet in CFX4.4. I have tried several times with different method. 1. I define INLET and MASS FLOW BOUNDARY as the inlet and outlet and define the flux of the MASS FLOW BOUNDARY as 1*1.0 and 1*0.0. The result is both gas and solid phase pass through the MASS FLOW BOUNDARY. 2. I define PRESSURE and MASS FLOW BOUNDARY as the inlet and outlet and define the flux of the MASS FLOW BOUNDARY as 1*1.0 and 1*0.0. The result is no solid came into the tank through the inlet. 3. I define INLET and MASS FLOW BOUNDARY as the inlet and PRESSURE and define the normal velocity of the oulet as zero by using USRBCS. The result is both gas and solid phase pass through the MASS FLOW BOUNDARY. 4. I want to define the outlet as Porous walls. But I do not know how to define.
Best regards!
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 08:20
Multiphase phase (gas-solid) flow using Eulerian-Granular medel ( divergence problem) jessie FLUENT 3 May 29, 2014 12:05
error in two phase flow problem mvee FLUENT 0 March 28, 2007 06:17
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
