howto model species transport with additional variable? |
December 25, 2017, 01:19 |
zmliu
Rep Power: 16 |
i need to model species transport with additional varialble.Then the density of working fluid must be defines as a funtion of addition variable,such as:Av1*5 [ ] *1[ kg m^-3] +1.225[kg m^-3].(Av1 is the name of additional variable)
when i begin the solutin ,show the error: Error processing expression 'Density'. The expression is invalid because: Av1 is not available for use in this term Error processing expression: Density = Expression 1 the question is that how to define the density of the fuid as a function of additional variable when i model species transport with additional variable? thank you very much! |
December 25, 2017, 04:11 |
Rep Power: 144 |
Why do this using an additional variable? Why not use a multicomponent mixture and all this functionality is built-in, including the numerics required to stabilise it.
December 25, 2017, 05:55 |
usama
Rep Power: 10 |
First of all, units of the expression should be stable.
additional variables, density, species transport |
Problem diverges: Scalar transport equation, variable: Species transport, material | shahrbanoo | AVL FIRE | 0 | July 24, 2014 09:52 |
Problem in Cell Zone conditions for Species Transport model | CFDP | FLUENT | 3 | March 5, 2013 05:14 |
Transport of additional variable | bearli | CFX | 4 | July 7, 2010 13:10 |
Species Transport Model | Sam | FLUENT | 0 | November 12, 2005 22:42 |
species transport model | soundar | FLUENT | 1 | February 3, 2005 15:13 |
