Adaptive meshing in CFX-5.5
Old   June 10, 2003, 23:04
Default Adaptive meshing in CFX-5.5
zahid
Hi all I have used adaptive meshing facility of CFX-5.5 for different problems. I think it does not produce satisfactory results. It is not so smart. Sometimes it refines the grid at places where it is not required. Has any body had good experiences in using adaptive meshing. If yes then please give me guidelines to obtain good results. Thanks
Old   June 11, 2003, 19:37
Default Re: Adaptive meshing in CFX-5.5
Hi Zahid,
To get adaptive meshing to do good things you have to set a number of parameters correctly. The most important is use the correct variables to refine with. If your model has been refining where it is not required it sounds like you have selected the wrong variable. Choose one which _only_ varies in the region of interest.
Also refining on variable*edge length can reduce over-refinement. It's worth a try too.
Glenn
CFX meshing moon1234 CFX 0 January 24, 2010 10:38
Which trailing edge is correct for meshing of aerofoils for CFX LSC CFX 0 May 10, 2009 13:45
CFX Meshing Error! C Mc Guinness Main CFD Forum 0 April 3, 2005 14:20
Geometry and meshing with CFX Bob Crad CFX 3 January 7, 2004 13:56
cfx, meshing + examples mark Main CFD Forum 1 December 22, 2000 00:10
