CFX4: 3d geometry
Old   June 10, 2003, 12:47
Default CFX4: 3d geometry
Ansah
Hello
I have been modelling a fluidised bed using a 2d geometry with the longest dimension deliberately drawn in the I direction. I am trying to generate a 3d version of the geometry, however, I have tried to produce the geometry such that the longest dimension is in the k-plane / z direction.
When amending my USERINT file to define a continuous and dispersed phase, I am unable to produce a suitable bed height in the plane of choice i.e longest length in z dir. Whatever I try, it's as if CFX solver can only produce the bed height in the X-direction. Is it necessary to have to produce the geometry with the longest dimension in the x direction?
thanks
Old   July 16, 2003, 22:10
Default Re: CFX4: 3d geometry
jeff
Ansah,
You can loop over all nodes and set your phase based on the XC,YC,ZC coordinates of each node. If you are above the interfacial Z-plane, set phases to 0 and 1 appropriately. If below, set them reverse. Make sure you loop over ALL the nodes using INODE = 1,NNODE.
Also, use the variables:
ZERO = 1.0E-10 ONE = 1.0 - ZERO
And use these variables to set your phases to either ONE or ZERO in each node.
Jeff
Old   July 17, 2003, 05:33
Ansah
Thanks for the advice Jeff
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
CFX4 geometry and command file a.melandinos CFX 1 February 14, 2002 13:37
CFX4 2d geometry sanjib das sharma CFX 16 July 10, 2001 06:56
