December 15, 2017, 02:45 |
Immersed Solid Valve Expressions
alper yıldırım
Rep Power: 12 |
Hello there,
I want to model a system using CFX with Immersed Solid. There is a bypass valve in the system. Rigid body and external force options do not fully cover my problem. For this reason, I created the motion equations of the valve myself. I have described Immersed Solid motion by the Specified Displacement method. the equations are giving the valve displacement value. In the equation there is the position and velocity term of the Immersed Solid body. I am having problems from these expressions. I give the expression I used below. areaAve (Total Mesh Displacement Y) @valve Wall ave (Mesh Velocity Y) @valve Valve Wall: valve's all walls (2D) Valve: Valve Region (3D) With the expression, I need an expression to calculate the position of the Immersed Solid Body every time step. At this point, I can define the valve displacement by using motion equations. Do I have a chance to calculate the position of the Immersed Solid Body with the Specified Deisplacement method? Could you tell me about the expressions I need to use? If necessary, I can describe the problem in more detail. Best Regards |
December 15, 2017, 04:01 |
alper yıldırım
Rep Power: 12 |
The other question,
if i use the rigid body solution with Immersed Solid method, how am i limit the valve position. For example: There is a check valve in the system. This valve is loaded with 400N preload. If I can limit the position of the rigid body to a point, I can stop the movement of the rigid body in case the force is not balanced. THX |
January 5, 2018, 00:15 |
Rep Power: 11 |
Rbstate(Position X)@rigid body name will give you position In the X direction.
I've seen a write up of limiting the position by using a logic statement in the motion equation you write. Something like new position = old position + If(rbstate(position x@rbname > max position, 0, dX as a result of the user defined equation of motion) |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Simulation of moving solid immersed in a two-phase flow | multiphaser | Main CFD Forum | 1 | October 6, 2016 16:19 |
Immersed Solid linked to Rigid Body Solver Query | Minty688 | CFX | 3 | July 28, 2015 06:47 |
Rigid body solution or Immersed solid | omidiut | CFX | 1 | July 3, 2012 02:36 |
Immersed Solid no flow! | exocubedesign | CFX | 3 | May 25, 2010 01:57 |
