How to improve the accuracy of the CFX?
Old   June 7, 2003, 10:45
Default How to improve the accuracy of the CFX?
Miko
Hi all! If I want to improve the accuracy of the result of calculation in CFX, what should I do? I know in the Mesh Parameters, timestep, Converge Control, Converge criteria, etc., we can improve the accuracy by properly setting. Is it right?
Miko
Old   June 7, 2003, 12:53
Default Re: How to improve the accuracy of the CFX?
zahid
Hi Miko Mesh parameters i.e. mesh refinement affects the accuracy of CFD calcualtions. But timestep size and convergence control parameters do not affect the accuracy of the CFD calcualtions. They are used to obtain a converged solution. If you do not set proper convergence control parameters then you will not be able to obtain a properly coverged solution. As far as I think discritization scheme is the most important thing that affects the accuracy of CFX solution.
Old   June 8, 2003, 18:38
Pascale Fonteijn
- Use at least high resolution or a blend of 1 for the advection scheme.
- you could use adaptive meshing.
Pascale
Old   June 10, 2003, 05:47
cfd guy
Yes, but I think that Miko should start checking the boundary conditions. If it's not properly set up you will get accuracy whithin the code, but wrong physical results.
Regards, cfd guy
Old   June 12, 2003, 22:24
Miko
Thank you all, zahid, Pascale Fonteijn and cfd guy! Your suggestions are very useful!
Best regards!
Miko
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 08:08
heat generation in CFX Ema CFX 4 August 7, 2009 06:39
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 12:08
CFX 10 in CFX 5.7 panneerselvam.R CFX 6 February 6, 2006 04:56
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
