what does this unit,[kg m^-2 s^-2], mean?
Old   June 5, 2003, 05:57
Default what does this unit,[kg m^-2 s^-2], mean?
Miko
Hi all! I creat a fluid sub-domain in CFX Build. When I press "Bulk Sources" and enable "Momentum Source", momentum along three direction can be found. I'm confused by the unit of the momentum, [kg m^-2 s^-2]. It also can't be changed into another one. Is anyone kind enough to let me know what it means?
Miko
Old   June 5, 2003, 10:41
Default Re: what does this unit,[kg m^-2 s^-2], mean?
bob
Is it just the momentum per unit volume, as you are applying the source term to a subdomain volume ? Bob
Old   June 5, 2003, 21:04
Miko
Hi Bob!
But if it means the momentum per unit volume, it should be [kg m^-2 s^-1}, I think.
Miko
Old   June 6, 2003, 09:11
zahid
Hi Miko It means Force per unit volume.
Old   June 7, 2003, 10:25
Miko
Thank you all! I think Zahid is right! [kg m^-2 s^-2] means force per uint volume, such as: (density)*(gravitational acceleration), (electric current density)*(magnetic field). Their dimensions are both equal to [kg m^-2 s^-2].
Miko
Old   June 9, 2003, 10:14
Bob
Hi Miko, yes you are right (or Zahid is), I was missing the seconds out. So would it be the same as saying Momentum per unit volume per second ? Bob
Old   June 9, 2003, 22:43
zahid
Hi Bob Yes you can say it rate of change of momentum per unit volume, and according to Newton's second law of motion it is equal to force per unit volume. Zahid
Old   June 12, 2003, 05:05
Miko
Yes, I agree with Zahid. In fact, momentum=force*time
Old   August 18, 2003, 10:19
CFX 4.3 users
most probably, it can be presure per unit length, cause, if you simplify the unit of pressure [F/A] it becomes kg/(m.s^2). check it out if my suggestion gives sound to what you are doing
bye
Old   September 1, 2003, 17:29
George
it means temporary change of momentun per unit of volume, analyze it and you'll see.
Old   January 14, 2024, 11:18
Abdulaziz Abutunis
ama294 is on a distinguished road
In fluid, it is the unit of the specific weight (gamma = rho . g)
ama294 is offline   Reply With Quote
