Hi all,
In CFX4.4 I get the following error (in the output file): INSUFFICIENT SPACE ON MACHINE TO ALLOCATE MEMORY CFX-4 STOPPED Is this error related to ram or hard drive space? I know that I'm pushing the limit of the amount of physical memory required but I'm also wondering whether I'm running out of hard disk space. With the -dir option: => -dir /model/.cfx4_tmpdir Does anyone know how much hard drive space is required as compared to the amount of physical memory? eg, for a 1GB ram model, how much space does CFX-4 need for its temporary directory? cheers, Novak. |
Hi Novak,
The first question is; what is the grid size? Your RAM seems OK for a 'general' simulation. There are 3 accations that I have seen this message: (1) When, in the postprocess, i become over ambitious and select many blocks/planes for vector plot, fringe plot etc (2) when i model a 2-phase 3D system on less than 0.6GB RAM machine. (3) When there is an interruption in the license acquisition (I call this false alarm!!). regards Nyatoto |
Hi Nyatoto,
I have around 450000 internal cells, my solution was not grid independent with half that number of cells so I continue to refine the grid. My model is a single phase, laminar transient flow problem with moving and deforming grids and an adaptive mesh (user fortran). I'm not running the CFX-LINEGRAPH to dynamically plot the residuals since this program (line.exe) uses up as much memory as the solver (runsolve4)! The problem is only in the solver, pre-processing doesn't present a problem and I haven't got a solution to post-process yet with this grid. There are no problems with the licencing. Any thoughts? I guess I'll know the answer as soon as I can get my hands on a machine with more memory! Novak. |
Then it appears the problem could just be the memory.
regards Nyatoto |
Memory requirements of OF tools | bastil | OpenFOAM Running, Solving & CFD | 5 | May 1, 2016 17:19 |
Memory requirements for serial and parallel runs | denner | OpenFOAM Running, Solving & CFD | 0 | August 26, 2008 15:11 |
CFX CPU time & real time | Nick Strantzias | CFX | 8 | July 23, 2006 17:50 |
memory requirements - beowulf cluster | mary | FLUENT | 3 | November 20, 2004 08:53 |
CFX-5.7 - Serial PC Maximum Memory Requirements | James Date | CFX | 15 | November 16, 2004 11:05 |
