GGI interface and meshing
Old   June 2, 2003, 04:50
Default GGI interface and meshing
Vincent
Hi everybody, I try to simulate the heat transfer in the roof of a road tunnel during a fire. Because of this, I use different imported domains with different kind of mesh. My problem is that on an interface between a cubic mesh and an irregular mesh, I have differences of velocity and temperature fields, specially where I have important gradient. I think the problem comes from the differences between the size of the elements of each part and I like to know how elements have to be at an interface to keep a good continuity of fields. Thanks.
Old   June 2, 2003, 06:01
Default Re: GGI interface and meshing
vlado
if you have a big gradients and if you want to get good results you ned to have very dense nodes especialy in boundary layer. So the first step is to increase the node density in both meshes on the contatct surfaces.
Old   June 2, 2003, 13:32
Danie
Hi Vincent, It would be good if you have similar edge length across the interface. Moreover, having a inflation on the unstructured side with prism heights corresponding to that of structured side would improve the gradient resolution. An important note to make is GGI captures accurately gradients which are across GGI, but gradients along interface are poorly captured. You may have to redo the interface accordingly.
All the best, Danie
Old   June 4, 2003, 04:29
Vincent
Thanks, If it could help someone, there is a patch on the cfxcommunity site. This patch resolves the problems that you could meet with a flow parallel to the interface. It is strongly recommended to install it if you use GGI interface with CFX 5.5.1.
[Other] mergePatchPairs for a meshing with fixed interface Cyp OpenFOAM Meshing & Mesh Conversion 17 May 22, 2014 10:34
[Commercial meshers] non conformal interface, meshing, inverted volume araghunath OpenFOAM Meshing & Mesh Conversion 1 April 7, 2011 05:27
Multiregion meshing with interface in between regions bhaskar STAR-CCM+ 2 June 23, 2009 07:06
Meshing around domain interface Tom S CFX 0 August 1, 2008 06:31
Dynamic meshing at phase interface Scotia FLUENT 0 March 3, 2008 13:55
