May 28, 2003, 06:13 |
Translating frame of reference
Hi, I am trying to model a body moving through a fluid domain. I have already got results by modelling the body as stationary and defining inflows into the domain. However ideal I would like to give the body itself a velocity, using a moving mesh. It seem that this would be possible using a moving coordinate system... however I have no clue how to achieve this. Any suggestion would be gratefully recieved. Thank you Blair
May 28, 2003, 06:14 |
Re: Moving frame of reference
Sorry, I think this title is more appropriate for my original post
May 28, 2003, 19:13 |
Hi Blair,
Which code are you using? But you definitely can do this in CFX4, and you should be able to do this using the moving grid beta feature in CFX5. Glenn |
June 2, 2003, 08:13 |
I am using CFX5.5.1
I have not been able to find the moving grid beta feature in any of the help files. I would greatly appreciate any suggestions. blair |
June 2, 2003, 19:51 |
Hi Blair,
It is not documented because it is a beta feature, and hence not guaranteed to be correctly implemented. I understand that it is planned to be part of CFX 5.7, which is quite some time off release yet! I have emailed you a def file which demonstrates moving grids in CFX5.5.1/5.6. Be warned - as it is a beta feature it is not guaranteed to be accurate, and has some weird quirks - it is not for inexperienced users of CFX. But I have managed to do some interesting work using it, so if you're keen give it a go. Glenn |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 05:28 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 01:34 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 10:27 |
