May 26, 2003, 22:30 |
Another question on Free Surface
Now I have another question. For free surface flow in vacuum, how can I simulate it?
May 27, 2003, 17:42 |
Re: Another question on Free Surface
Hi Miko,
This is not physically realistic. To have a liquid free surface, there must be some gas phase applying pressure. If you like, you can specify your second phase to have a very small density, but I suspect you will have problems if it is too small. Robin |
May 27, 2003, 22:13 |
Hi Robin,
Yes, you are right. I think I should apply a certain gas around it. If the density of the gas is small but with certain value of pressure, is it possible? |
May 28, 2003, 10:53 |
Yes, but if the density of your gas is too low, you may experience convergence problems.
Robin |
May 28, 2003, 21:31 |
Hi Robin,
Oh, I see. OK, I will pay attention it. Thank you! Best regards! Miko |
May 30, 2003, 06:06 |
I recommend that you calculate Knudsen number (mean free path / reactor dimension) for the gas side. It should be <0.1 otherwise the continuum assumption inherent to CFD codes is no longer valid.
Peter |
Linear analytical solution oto the 2D free sloshing water surface elevation | bearcat | Main CFD Forum | 7 | August 5, 2011 21:13 |
Free surface question | Jay | FLUENT | 0 | January 19, 2009 01:15 |
free surface flow simulation question | Jane | Main CFD Forum | 0 | April 22, 2004 14:25 |
Free Surface Modeling | willy | FLUENT | 11 | July 17, 2001 08:07 |
Variable Density - Free Surface with FIDAP | Vitaliy Pavlyk | FLUENT | 7 | May 2, 2000 16:56 |
