December 20, 2017, 17:37 |
#41 |
Rep Power: 144 |
Are you in China? If so then I suspect your government has blocked google which means my google drive link does not work.
December 20, 2017, 20:43 |
[QUOTE=ghorrocks;675739]Are you in China? If so then I suspect your government has bl
#42 |
wan zhihua
Rep Power: 8 |
Yes,you are right,I am sorry that our country has block the google,I think the only way is to send the screen capture pictures to the CFD online,I know it is very disturbing you,if you are convinent ,I would hope you could help me,I am glad to recognize you ,you are friendly ,I wonder if the MSN can send to you ?Thank you.
December 21, 2017, 03:52 |
#43 | |
wan zhihua
Rep Power: 8 |
IMG_4879.jpg 1Y)U(S9]N}LU}TSOKAM24.png you can see my model ,in my model ,I choose the gas inlet,liquid inlet and outlet as a periodic interface,but the mass flow is to the all face ,I cannot give it to the liquid face,how can you solve it ?Thank you. |
December 21, 2017, 17:20 |
#44 |
Rep Power: 144 |
As water has 1000 times the density of air, if you specify the water mass flow rate as the total mass flow rate you will not be off by much. Other errors will be larger than that.
December 21, 2017, 21:30 |
[QUOTE=ghorrocks;675846]As water has 1000 times the density of air, if you specify th
#45 | |
wan zhihua
Rep Power: 8 |
What is "off by much",I cannot understand your meaning,the mass flow is neither to the water nor to the air ,I do not know which fluid it will refer to, and I know this setting is wrong ,I want to see how you setting this mass flow rate ,maybe your model is different from me,can you send your setting images like my images sent to you to me ,thank you very much. |
December 21, 2017, 22:10 |
#46 |
Rep Power: 144 |
If you say the flow rate is 1kg/s for water, but that is spread over a volume fraction of 50% water and 50% air, then you will be off by about 1 in 1000 from the density difference. That is a negligibly small error in most cases. So it is not worth spending much time fixing it as the error is very small. Spend your time on much larger errors like mesh refinement and convergence tolerance.
I have removed the results files from the example and this has made it small enough to email. Please PM me your email address and I will send it to you. |
December 22, 2017, 22:58 |
[QUOTE=ghorrocks;675859]If you say the flow rate is 1kg/s for water, but that is spre
#47 | |
wan zhihua
Rep Power: 8 |
Thank you for your kindness.but I want the the volume of the liquid inlet is 100% ,the volume of the gas inlet is 100%,if I give the mass flow rate ,I cannot set this.My email is wanzhiha@stu.xjtu.edu.cn, another email is hitzhwan@163.com,thank you very much. Last edited by zhihuawan; December 22, 2017 at 22:59. Reason: do you have any reference books for learning CFX operation? |
December 23, 2017, 07:09 |
#48 |
Rep Power: 144 |
I have just emailed you the file. I have removed the results files so it is small enough to email.
December 23, 2017, 20:32 |
[QUOTE=ghorrocks;675932]I have just emailed you the file. I have removed the results
#49 |
wan zhihua
Rep Power: 8 |
I am extraordinary grateful for your sending the file to me, I find you are very intelligent to use the step function to solve the liquid and air inlet in the steady calculation,we can see a clear gas-liquid interface in the figure 1,but when I use your transient calculation with the result of steady result,the caculation step is about 300(Figure 2) ,but I find the clear interface of air and water is not clear,they are mixtured together,so I the uniform mass flow is not available way to solve the probelm, do you think so?Thank you very much.
December 23, 2017, 20:55 |
#50 | |
wan zhihua
Rep Power: 8 |
fig2 caculation.jpg fig3 water volume fraction.jpg This is figures,do you get the same result? |
December 25, 2017, 04:10 |
#51 |
Rep Power: 144 |
When the solution goes all over the place (that is, not converging properly) then the interface will get smeared and you will not be able to recover it. You have to make sure the simulation converges for all time steps.
Also note I used a laminar flow model. The flow is probably turbulent so should have a turbulence model. It will be unstable with a laminar flow model. |
December 25, 2017, 09:18 |
[QUOTE=ghorrocks;676040]When the solution goes all over the place (that is, not conve
#52 | |
wan zhihua
Rep Power: 8 |
In my simulation ,the velocity is small to 0.09m/s,so the Re number is less than 1000,so we can choose the laminar model ,the model may not be the problem ,as to your advice,I will change the setting to have a good coverging level,thank you very much. |
December 25, 2017, 18:38 |
#53 |
Rep Power: 144 |
You can easily test whether your opinion or my opinion is correct by running a transient simulation which converges tightly at each time step. Having said that, you should be doing this anyway for a transient simulation where you want an accurate time history.
If your flow is in the laminar regime then just use a laminar flow model. Don't model physics which you know does not exist. |
December 26, 2017, 09:03 |
[QUOTE=ghorrocks;676097]You can easily test whether your opinion or my opinion is cor
#54 | |
wan zhihua
Rep Power: 8 |
I have done as you said ,I have choose inlet codition to the laminar flow ,but I met a error after it calculate a few times, this are the error images,I have send the case file to your e-mail, I find there are so many problems for me to solve.Thank you very much. [ATTACH]error.jpg error2.jpg momentum and mass .jpg user point.jpg volume.jpg[/ATTACH] |
December 26, 2017, 17:41 |
#55 |
Rep Power: 144 |
In future please just attach the output file. That gives all the details required to debug CFX. The error dialog boxes in Workbench are usually not very useful.
Again, this appears to be inadequate convergence. You need to make sure that every time step is converged. In free surface models the time step required for good convergence can vary a bit due to surface waves on the surface. This means it is really good to use adaptive time steps, homing in on 3-5 coeff loops per iteration. This means the solution can adjust the time step as required. |
December 26, 2017, 22:19 |
[QUOTE=ghorrocks;676173]In future please just attach the output file. That gives all
#56 | |
wan zhihua
Rep Power: 8 |
(2)What is good adequate convergence,you mean every variables should below the 1e-4,I see the water-air interface in the steady calculation is not clear in my result ,which is different to your case.Can you receive my file from the e-mail? (3)I find there is no adaptive time steps in the software when I choose the transient calculation,you can see the images,which one should I choose?analysis type.jpg solve control.jpg water volume.jpg |
December 28, 2017, 18:19 |
#57 |
Rep Power: 144 |
1) If you don't have an output file then please attach the CCL.
2) The exact convergence tolerance required varies depending on the simulation. You may need to be higher or lower. Do a sensitivity analysis to find the convergence you require for accurate results. 3) The adaptive time step option is under the "Timesteps" option. You currently have that set to a fixed 0.0001[s] |
January 3, 2018, 20:55 |
[QUOTE=ghorrocks;676339]1) If you don't have an output file then please attach the CC
#58 | |
wan zhihua
Rep Power: 8 |
when I try to set the timesteps to 1e-6,after a long time ,it will give a error ,the out files are as following: This run of the CFX Release 18.0 Solver started at 21:39:13 on 03 Jan 2018 by user dell on DELL-PC (intel_xeon64.sse2_winnt) using the command: Setting up CFX Solver run ... +--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+ LIBRARY: CEL: EXPRESSIONS: Press = (1-step((y-0.0009[m])/1[m]))*960*cos(45)*g*y END END MATERIAL: air 300K Material Group = User Option = Pure Substance PROPERTIES: Option = General Material EQUATION OF STATE: Density = 1.1766 [kg m^-3] Molar Mass = 1.0 [kg kmol^-1] Option = Value END DYNAMIC VISCOSITY: Dynamic Viscosity = 1.8537e-05 [Pa s] Option = Value END END END MATERIAL: silicone oil Material Group = User Option = Pure Substance PROPERTIES: Option = General Material EQUATION OF STATE: Density = 960 [kg m^-3] Molar Mass = 1.0 [kg kmol^-1] Option = Value END DYNAMIC VISCOSITY: Dynamic Viscosity = 0.0192 [Pa s] Option = Value END END END END FLOW: Flow Analysis 1 SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END ANALYSIS TYPE: Option = Transient EXTERNAL SOLVER COUPLING: Option = None END INITIAL TIME: Option = Automatic with Value Time = 0 [s] END TIME DURATION: Option = Total Time Total Time = 1 [s] END TIME STEPS: Option = Timesteps Timesteps = 1e-006 [s] END END DOMAIN: Default Domain Coord Frame = Coord 0 Domain Type = Fluid Location = fluid BOUNDARY: Domain Interface 1 Side 1 Boundary Type = INTERFACE Location = inlet BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: Domain Interface 1 Side 2 Boundary Type = INTERFACE Location = outlet BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: opening Boundary Type = OPENING Location = opening BOUNDARY CONDITIONS: FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Opening Pressure and Direction Relative Pressure = 0 [Pa] END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END FLUID: air BOUNDARY CONDITIONS: VOLUME FRACTION: Option = Value Volume Fraction = 1 END END END FLUID: silicon oil BOUNDARY CONDITIONS: VOLUME FRACTION: Option = Value Volume Fraction = 0 END END END END BOUNDARY: side interface Side 1 Boundary Type = INTERFACE Location = periodic BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: side interface Side 2 Boundary Type = INTERFACE Location = periodic_shadow BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: wall Boundary Type = WALL Location = wall BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END FLUID PAIR: air | silicon oil BOUNDARY CONDITIONS: WALL ADHESION: Option = Adhesive Wall Contact Angle = 45 [degree] END END END END DOMAIN MODELS: BUOYANCY MODEL: Buoyancy Reference Density = 1.1766 [kg m^-3] Gravity X Component = 0 [m s^-2] Gravity Y Component = -g Gravity Z Component = 0 [m s^-2] Option = Buoyant BUOYANCY REFERENCE LOCATION: Option = Automatic END END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: air Material = air 300K Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID DEFINITION: silicon oil Material = silicone oil Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END FLUID: air FLUID BUOYANCY MODEL: Option = Density Difference END END FLUID: silicon oil FLUID BUOYANCY MODEL: Option = Density Difference END END HEAT TRANSFER MODEL: Homogeneous Model = Off Option = None END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = k omega BUOYANCY TURBULENCE: Option = None END END TURBULENT WALL FUNCTIONS: Option = Automatic END END FLUID PAIR: air | silicon oil Surface Tension Coefficient = 0.0206 [N m^-1] INTERPHASE TRANSFER MODEL: Option = Free Surface END MASS TRANSFER: Option = None END SURFACE TENSION MODEL: Option = Continuum Surface Force Primary Fluid = silicon oil END END MULTIPHASE MODELS: Homogeneous Model = On FREE SURFACE MODEL: Option = Standard END END END DOMAIN INTERFACE: Domain Interface 1 Boundary List1 = Domain Interface 1 Side 1 Boundary List2 = Domain Interface 1 Side 2 Interface Type = Fluid Fluid INTERFACE MODELS: Option = Translational Periodicity MASS AND MOMENTUM: Option = Conservative Interface Flux MOMENTUM INTERFACE MODEL: Mass Flow Rate = 0.57 [kg s^-1] Option = Mass Flow Rate END END END MESH CONNECTION: Option = GGI END END DOMAIN INTERFACE: side interface Boundary List1 = side interface Side 1 Boundary List2 = side interface Side 2 Interface Type = Fluid Fluid INTERFACE MODELS: Option = Translational Periodicity MASS AND MOMENTUM: Option = Conservative Interface Flux MOMENTUM INTERFACE MODEL: Option = None END END END MESH CONNECTION: Option = Direct END END OUTPUT CONTROL: RESULTS: File Compression Level = Default Option = Standard END TRANSIENT RESULTS: Transient Results 1 File Compression Level = Default Include Mesh = No Option = Selected Variables Output Variables List = Absolute Pressure,air.Volume \ Fraction,air.Velocity,silicon oil.Velocity,silicon oil.Volume Fraction OUTPUT FREQUENCY: Option = Timestep Interval Timestep Interval = 10 END END END SOLVER CONTROL: Turbulence Numerics = First Order ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 50 Minimum Number of Coefficient Loops = 1 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Domain Interface Target = 0.0001 Residual Target = 1.E-4 Residual Type = RMS END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END END COMMAND FILE: Version = 18.0 Results Version = 18.0 END SIMULATION CONTROL: EXECUTION CONTROL: EXECUTABLE SELECTION: Double Precision = No Large Problem = No END INTERPOLATOR STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 END END PARALLEL HOST LIBRARY: HOST DEFINITION: dellpc Remote Host Name = DELL-PC Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX Host Architecture String = winnt-amd64 END END PARTITIONER STEP CONTROL: Multidomain Option = Automatic Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARTITION SMOOTHING: Maximum Partition Smoothing Sweeps = 100 Option = Smooth END PARTITIONING TYPE: MeTiS Type = k-way Option = MeTiS Partition Size Rule = Automatic Partition Weight Factors = 0.12500, 0.12500, 0.12500, 0.12500, \ 0.12500, 0.12500, 0.12500, 0.12500 END END RUN DEFINITION: Solver Input File = E:\moni\yyq2\shuntai_005.res Run Mode = Full Solver Results File = E:\moni\yyq2\shuntai_006.res END SOLVER STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARALLEL ENVIRONMENT: Number of Processes = 8 Start Method = Intel MPI Local Parallel Parallel Host List = dellpc*8 END END END END +--------------------------------------------------------------------+ | | | ---------+ | The Equations Solved in This Calculation | +--------------------------------------------------------------------+ | | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver could not be started, or exited with return | | code 255: . No results file has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | The following transient and backup files written by the ANSYS CFX | | solver have been saved in the directory E:\moni\yyq2\shuntai_006: | | | | 220.trn | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | E:\moni\yyq2\shuntai_006: | | | | pids, mon | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Warning! | | | | After waiting for 60 seconds, 1 solver manager process(es) appear | | not to have noticed that this run has ended. You may get errors | | removing some files if they are still open in the solver manager. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. can you help me ?I do not know how to send you file ? |
January 4, 2018, 01:38 |
#59 |
Rep Power: 144 |
You are running a free surface simulation with surface tension. You will find that to get this to converge you will need amazingly small time steps. Surface tension modelling increases the simulation's sensitivity to time step size. So try smaller time steps. Even better, use the adaptive time steps I recommended before (adaptive time steps works very well for this class of simulations).
January 7, 2018, 03:38 |
[QUOTE=ghorrocks;676876]You are running a free surface simulation with surface tensio
#60 | |
wan zhihua
Rep Power: 8 |
cfx, interface, periodic, translational |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 11:20 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
Confused about periodic interface | Jeff | STAR-CCM+ | 3 | August 15, 2012 23:30 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 08:22 |
Periodic Interface | Magnoli | CFX | 0 | November 7, 2007 08:51 |
