May 16, 2003, 15:37 |
Batch mode for CFX5.5.1 on Windows
Hi, there,
Can anyone tell me if CFX5.5.1 supports the batch mode runs on Windows? If yes, where can I find some sort of turtorial to get started? Thanks. |
May 16, 2003, 16:42 |
Re: Batch mode for CFX5.5.1 on Windows
CFX-5 solver is always run in batch mode, even from the solver manager. Use the command 'cfx5solve'. You will need to put the CFX-5 bin directory in your path or open a command line from the launcher.
To launch a run, simply enter the command: cfx5solve -def myRun.def To continue an existing run: cfx5solve -def myRun_001.res etc. For more info on cfx5solve, enter 'cfx5solve -help'. Regards, Robin |
May 18, 2003, 09:59 |
hi robin ,can you tell me if cfx4 can run in batch mode? Thank you!
May 18, 2003, 17:58 |
That is very well explained in the manual, if you have one .......
Pascale |
May 19, 2003, 10:09 |
Re: Batch mode for CFX5.5.1 and CFX-4
All of the above is in the manual...
In CFX-4 type runsolve4 - help and you will have all the info you need too. |
Running Ansys in BAtch Mode | kuleuvenstudent | ANSYS | 1 | October 18, 2017 13:11 |
Running FLUENT in batch mode for Windows OS | Jake Lee | FLUENT | 7 | June 29, 2016 09:38 |
Run ansys 12.0 using batch mode (windows xp) | mayan | ANSYS | 2 | May 25, 2016 09:02 |
to run a replayfile in batch mode from UNIX | froztbear | ANSYS Meshing & Geometry | 4 | May 13, 2014 09:00 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
