May 5, 2003, 10:16 |
Streaklines
I am having problems to use particle tracking. Does anyone know how to create/visualize streaklines in the CFX 5.5.1 ? Thank you |
May 5, 2003, 10:42 |
Re: Streaklines
Hi, If you just want to follow a particle, you have to create a point at the location of the particle you want to follow and then create a streamline based on this point, you can do the same with a line or a plane. You have all informations in the CFX help and you can try the tutorial 3.
May 5, 2003, 12:00 |
Re: Streaklines
Thank you, but to the CFX streamline and streakline have the same meaning ? Streamline is diferent of streakline. Thank you again.
May 5, 2003, 19:23 |
Re: Streaklines
Hi Christian,
In steady state flow streamlines and streaklines are the same thing. In transient flow, streamlines are the path a massless particle would take if the flowfield of that instant in time is used, and streaklines are the path the massless particle would take if the flow field is allowed to change with time. That's a physical description, you will probably find a more mathematical description in your textbook. CFX 5.5 can do streamlines in steady state and transient flow, and CFX 5.6 will do particle tracking (with and without mass) in steady-state flows. I believe you will have to wait until CFX 5.7 for true streaklines! Regards, Glenn Horrocks |
streaklines in fluent | CFDstudent123 | FLUENT | 1 | August 25, 2014 04:21 |
plot streaklines in tecplot360 | student | Main CFD Forum | 1 | August 25, 2014 04:20 |
Pathlines - Streaklines | Dr.J | CFX | 2 | April 7, 2009 20:50 |
streamlines, streaklines for 3d flow | amol palekar | Main CFD Forum | 2 | April 20, 2005 10:51 |
