aspect ratio
Old   May 2, 2003, 03:41
Default aspect ratio
ditto
halo friends,
I have a model of a typical valve meshed in CFX- 5.5.1 in which the aspect ratio shoots high as upto 830. I tried to reduce this as much as possible.But i want to know the effect of this high aspect ratio elements when we are solving it.since my flow path being complex i am unable to reduce the ratio further .Any help in sorting it out , please?
- DITTO
Old   May 3, 2003, 23:13
Default Re: aspect ratio
Robin
Hi ditto,
If the high aspect ratio elements are aligned with the flow, such at along a wall, the effect may not be significant. If the flow is not aligned, you may run into local convergence difficulties and the accuracy in this region will be somewhat reduced. Just how much will be problem dependent.
Robin
Old   May 4, 2003, 00:55
ditto
halo robin,
The problem i have is about the flow of steam through a valve where it looses its pressure and temperature by mixing with water.so now how much the high aspect ratio elements will affect this?.Moreover in cfx upto what aspect ratio we can proceed?. Thank you for your reply.
- ditto
Old   May 5, 2003, 11:16
Robin
Without seeing the model, anything would be a guess. I suggest contacting your support rep for help.
Robin
Old   May 6, 2003, 07:27
ramkumar
hi ditto,
Even though there is a thumb rule that the aspect ratio of unstructured mesh must be less than 5 and for structured mesh it can be upto 200, in solving typical high aspect ratio problems such as tunnels, etc which are very long compared to diameters cfd experts have comfortably used aspect ratio as high as 400 so i think ,it wont affect much but for some convergence problems which you can overcome by proper selection of timestep.
Old   May 6, 2003, 13:09
Robin
Hi Ramkumar,
...in solving typical high aspect ratio problems such as tunnels, etc which are very long compared to diameters cfd experts have comfortably used aspect ratio as high as 400...
This is only because the flow is aligned with the grid, which may not be the case here.
...there is a thumb rule that the aspect ratio of unstructured mesh must be less than 5 and for structured mesh it can be upto 200...
This is a good point, but should not be generalized to structured or unstructured. Rather, it has to do with element type (and really more to do with skew than aspect ratio). You can have a high aspect ratio hex or prism element which still has reasonable skew, however if you stretch a tet element, the skew will always be poor.
Ditto: what element type are your high aspect ration elements? How is the skew angle?
Regards, Robin
Old   May 9, 2003, 00:51
ditto
halo robin,
I am using unstructured tet element for the model.As you asked the maximum face angle is 172 and minimum face angle is 0.6.so how to go about?
- ditto
Old   May 11, 2003, 12:19
Robin
Ditto,
A minimum face angle of 0.6 degrees will cause problems. Your best bet is to go back to the mesher and add mesh controls in this region, or modify your geometry to improve the mesh quality.
Robin
High aspect ratio oort OpenFOAM 5 September 16, 2011 15:06
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 08:42
[ICEM] Mesh along axis for a wedge gives elements with extreme aspect ratio sangrampp ANSYS Meshing & Geometry 0 November 17, 2010 07:57
aspect ratio vs. y+ hammam CFX 3 August 6, 2007 11:41
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 13:01
