Global length
Old   April 30, 2003, 04:58
Default Global length
Dustin Lee
Dear all: Can someone please tell me "How the Global lengeh is calculated?" from CFX-5.5 out-file.
Old   April 30, 2003, 12:33
Default Re: Global length
Robin
Square root of the volume.
Old   May 1, 2003, 03:13
SHRINIVAS
dear..
I saw your reply for a question about global length. you told it is square root of volume. If so, which cell volume, as this volume change from cell to cell
bye
Old   May 1, 2003, 14:57
Robin
The volume of the entire mesh, hence the GLOBAL length scale.
Robin
Old   May 2, 2003, 01:49
Dustin Lee
Thanks to Robin & Shrinivas. When I simplied the volume, its clear that the "Global length" scale is the "cubic root of the Volume".
Old   May 3, 2003, 23:08
Robin
Sorry, cube root of the volume :-P
Old   May 14, 2003, 18:43
cfxuser
You should really calculate your own characteristic length scale appropriate to the problem, as the value calculated based on the cubed root of the domain volume rarely produces a value appropriate for the physical problem, the same for the time-scale also.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
