April 29, 2003, 04:41 |
slidding grid
Hi All,
I use both CFX4.4 and CFX5.5.1. In the manual, I have seen that it is written somewhere that when you have SLIDDING GRIDS/UNMATCHED BOUNDARY then the REBLOCK in the VOLMSH should be OFF. However, in the Application example5 (CFX4.4) given in the manual, (in which unmatched boundary is used) the intruction says that " Make sure REBOLCK IN VOLMSH is ON!! I have been doing my simulation with the re block on with unmatched boundary set, could some one tell me whether I am doing the correct thing. Note that I have compared my problems with experimental data and other people simulations, and I can see that there is good agreement. Further, VOLMSH warns me that, when the reblock is on the names of the block will change. However, when i read the mx.geo file for both the ON and OFF approaches, I cant see any difference!! Could there be something I am missing? thanks for taking your time to read this. thanks nyatoto |
May 9, 2003, 16:59 |
Re: slidding grid
Nyatoto,
I use CFX4.4 with silding grids and always reblock in volmesh. I have not encountered any difficulty resulting from reblocking, but it's a good idea to review the new block structure if you use the create patch command, output monitor block, or one of the user fortran routines. Typically volmesh significantly reduces the number of blocks, so it is unlikely that the geo file for both the on and off approaches would be identical unless the geometry is already optimized. John |
May 11, 2003, 11:34 |
Re: slidding grid
Hi John, Thanks for taking your time to read this!
Just try two problems; one with reblock ON and the other one with OFF. I tried it and it appeared to me that they were identical when I read the geo file. However, I do agree with you,if you look at them in Postprocess, they are different. I have just started using SG. Something amazes me! In that system I had a rotating 3D patch for the inner block (call it USER3_ROTOR). When I set the rotating parameters for MFR, the USER3D_ROTOR name was recognized, however SG does not recognise this. If a give it the 'nick mane' that VOLMSH gave it with the reblock ON (say, BLOCK-NUMBER-1) it accepts that. Now the question comes; Why cant SG recogise the name I gave and yet MFR does? In fact, I could have expected both SG and MFR not to accept the names I gave because VOLMSH renamed my blocks anyway. Thus, I would expect the name VOLMESH gave to override the names I gave in Build. Why the difference?? Regards nyatoto |
May 12, 2003, 11:35 |
Re: slidding grid
Nyatoto,
I would like to hear more about how and why you name the blocks in build. I can't say that I do that. If you use volmesh to optimize the block structure, the number of blocks in the geo file will normally decrease. The number of blocks is the first number on the second line of the geo file. Compare the number of blocks in the two geo files so see if volmesh has reduced the number of blocks. Volmesh does not change the names of patchs assigned in build. So the name of your 3d patch will be the same for both a volmesh case and a non volmesh case. Since your SG case did not accept the 3d patch name but did accept the name BLOCK-NUMBER-1, you sould verify name for the 3d patch by reviewing the name geo file. Make sure that the 3d patch name entered in the command file under grid motion parameters is identical to the name in the geo file. My experience is that both SG and MFR will work with the a USER3D patch name. Regards, John |
May 13, 2003, 08:18 |
Re: slidding grid
Hi John,
Thanks for your contribution. I do not name the blocks, I create a 3D-patch with a group of blocks( say BLOCK-NUMBER-1,2,3, 4 etc).What i saw VOLMSH does with REBLOCK ON is that the group that comprised the USER3D-XX is given a name like BLOCK-NUMBER-1, and now SG was not accepting my USER3D-XX name. What i did is that I took the 'fc' and 'geo' files from the my steady state simulation and modified the fc, putting in the transient parametrs. It refused to accept my 3D-patch!! If you said that it should ACCEPT, then I will take your word and relook at the whole thing. regards nyatoto |
May 13, 2003, 08:19 |
Re: sliding grid
Hi John,
May 13, 2003, 18:03 |
Re: sliding grid
Hi Nyatoto,
Yes, I use the USER3d patch name in the gid motion parameters. PATCH NAME 'USER3D_XX' I guess you can continue to use the block name as long as the rotating core is composed from a single block. Regards, John |
May 14, 2003, 06:05 |
Re: sliding grid
Thanks John, I will try it again. nyatoto.
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 15:17 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 14:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 09:32 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 06:59 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 17:43 |
